ADDING RESOURCES
S
samey uddin 👤 Member for 13 years 11 months
HII ,
 i  am doing a small project on STORM WATER DRAINAGE at various places ,and the resources involved in all the places for various activities involved in storm watrer are same ,so is there any shortcut to add resources or i have to add resources in each places individually ???
S
@Daniel Limson , thanks a lot i got the idea now i am selecting the resources i want to add and then like wise selecting all the activities for which i want to add the resources ..
@David Craig  ,thanx for your advice but i have followed the instructions of Daniel limson , and it was easy but i really like to learn adding same resources for many activities using FILL DOWN ,if  you can please explain it in detail steps !!! thank you .
Daniel Limson 👤 Member for 24 years 8 months
Samey,
You can select multiple Resources you want to add by pressing the upper arrow key (above the Ctrl) and then go to activities and do the same by selecting all the activities you want to add these resources or you can use filter and then add. simple right?
Daniel
Samey,
You can select multiple Resources you want to add by pressing the upper arrow key (above the Ctrl) and then go to activities and do the same by selecting all the activities you want to these resources or you can use filter and then add. simple right?
Daniel
David Craig 👤 Member for 16 years 8 months
Can you not add in the column for Primary Resource then just use the fill down feature?
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
