My P6 is very slow
Dear Friends
Iam working on Primaver 6 R8.1 - SQL SERVER 2005
my problem is that making any process now take extraordinary time. opening one file take may be 15 minutes, opening 2 files together to make any work take more than 30 minutes. i checked primavera background agent and found it working. also there i got some quiries in PDF file from one friend, i did these quiries but also didnt help.
please r there any method to make working faster i really loose my time now for nothing?
THANKS IN ADVANCE
Z
do this
Go to start
All programs
Select Microsoft SQL Server 2005
Then Microsoft SQL Server Management Studio
Server name is the name of your computer\PRIMAVERA
Authentication is SQL Server Authentication
Login: sa
Password is: Prima123Vera
Select Connect
On the left expand the databases and select pmdb$primavera
Uptop select New Query
on the right type this
update statistics project with fullscan ,all
update statistics task with fullscan, all
Then right click execute
Then type
exec sp_updatestats
K
Khuong Do 👤 Member for 16 years 3 months
When using Primavera P6 with Microsoft SQL Server database, we can have problem like this:
  • Loading Data hangs at 98%.
  • Performance issues in SQL Server.
  • Opening projects is slow.
  • PM.exe not responding after entering username and password.
  • Project Management window disappears after loading data.
  • Cannot login to PM, no error.
Here is the solution to solve above problem:
https://doduykhuong.com/2018/05/10/primavera-p6-sql-server-database-slow-loading-data-performance-issue/
IMAGE DELETED 5/11/2018 AS NO LONGER AVAILABLE ON THIS VERY OLD DISCUSSION THAT FOR SOME REASON WAS RESURRECTED AFTER BEING INACTIVE FOR SIX YEARS.
Make sure you have a backup of your database before it is too late.
Suggest calling ORACLE support team, they are very capable professionals that can guide you to a solution, I suppose although not obvious it shall be an easy solution as P6 is famous for its ease of use, so easy it is their favorite sales pitch.
H
hosam ebrahim 👤 Member for 14 years 7 months
Thanks alot mr Ronald, actually i know about this link and it didnt help i mentioned this in my question
Hosam,
 To solve your problem, try clicking on the link to the right of your question titled, “P6 locks up or is very slow when loading schedule.”  Good luck!
H
thanks for reply, but actually i can't delete any of the files which currently exist on my database. but i didnt reach the 4GB Limit till now. iam 3.5 GB now.
Daniel Limson 👤 Member for 24 years 8 months
Hosam,
Delete old files you do not use anymore. Back them up and delete (just in case you need them for reference in the future)
Always keep your database lean to keep it running smoothly.
Daniel
Haque Nawaz
EViLL1
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
