Budgeted Cost
In my Project Schedule i have addded only Material and Non Labor resources. I am able to manually edit the Budgeted Cost field in the Activity Deatils tab. However since this is a entity that is calculated by multiplying the Budgeted Units with the Price/Unit then how is it that i am manually able to edit the Budgeted Cost field and the Budgeted Unit field do not change correspondingly.
For example:-
I have Pipes as a resouce with a Price/Unit of Rs.2500/meter.
I assigned this resource to an activity " Laying Bridge Rack CHW Pipes" and i estimated that 150 meters of pipe will be required for this activity.
So the Budgeted Cost = 2500 X 150=Rs. 375,000/-
But after i do this how am i still amble to manually edit the Bidgeted Cost field and then why does the Budgetd Units field remain unaffected after the change is done to the Budgeted Cost.
Am I  missing a setting ????????????????????
K
Kannan CP 👤 Member for 18 years
Abdullah,
It is possible to manually change the Budgeted Cost. But if you go to Tools......Recalculate Assignment Cost, cost will be in line with the Budgeted Units.
Kannan
M
mahmoud el shamy 👤 Member for 14 years 4 months
hi abdullah
what do you mean by budget cost field
please reply to make me help you
thank you
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Nick Johnson-Pond
