I have loaded my P6 schedule with 17 resources and I have entered "planned" units resource numbers for each resource/each activity.
When I pull up the resource graph, the planned units only show up in the first month (for example: 3 month activity with 96 hours... all 96 hours are in month one).
I know this is a setting somewhere. I've searched, but no luck.
Thanks! Bill
"You can try setting the "Resource Units/Time" for each activity to a value that gives you an even spread over the duration of the activity. You can add a column "Resource Units/Time" column in your Resource tab. You will have to provide a value for each resource in each activity. "
I'll be trying that on Monday morning... That was also recommended by a co-worker, but I didn't have a chance to try it today. To busy!!!
Thanks for your help!
Bill................
Hi Bill
Check the histogram is for selected activities or for all activities
Cheer's
Shahul
No. I am not using any resource curves. I did some searching. There are some different things I can try.
Anything to do with resource curve type? Front loading or manual curve settings?
