Application Error?!?!?!
Hi all,
Any advice that you have on this would be very much appreciated.
My colleagues and I continually get the following Application Event Error, Event Code AVAA3-3325-E. We only get this error if we try and use any of the four print options:
Page SetUp
Print SetUp
Print Preview
Print.
We do not get any errors if we use any other function i.e. re-schedule, changes layouts etc etc. The very strange thing is that one of our other colleagues, in the same building and accessing P6 via the same citrix platform does not get the error code,,,
as always, many thanks
Jon
Dieter Wambach 👤 Member for 19 years 4 months
Jonathan
I assume that you didn't assign a printer to your pc.
Start --> (depending on your Windows) printers & Faxes --> assign a printer (which is able to print at least A3, eg. HP 750 PPlotter) even if you don't have a printer. For those functions Primavera uses the driver of the assigned printer. If you work under Citrix, ask your IT.
Good luck!
S
Shah. HB 👤 Member for 17 years 6 months
Hi Jonathan Ward
I faced this issue but for a  day then it got disappeared .Try by restarting the system
Shahul
