I have exported all activities so I can update some codes, when I try to import P6 after making the changes, p6 asks for "Import to" selection I can select but I see none of the projects is my database. any Ideas why this would be blank? I actually thought it would select the opened project by default
Excel Import Issue
HI Ron,
Click on the empty space in project and you will get a pop up to choose the project. There you can see your current opened project. I suggest you use SDK to update project data if you want to do it in bulk.
Amit Parmar
check out my blog on Primavera at http://www.primaverablog.in
