Hey, trying to export a P6 project to MS Project, every time I run through the process it says completed but with errors, please see log, the information in the log isn't particularly helpful and I can't see where I'm tripping up.
Does anyone have experience of this process?
Hey Andy
I'm using the latest version of Primavera 6.7 and trying to dump a Project into MS Project 2003. I was using XML 2002/2003.
I'll have a try with your suggestion and see how I go. Worst case scenario I can easily copy the P6 information in Excel, then copy it across into MS Project, but that means reinserting all my activity relationships and reorganising all my activities which I wanted to avoid doing.
Aaron
Primavera and MS Project aren't 100% compatible with each other when you exchange data between the two, so it's always worth checking the results!
Which format of MS Project export are you using? MPX? XML 2002/2003? XML 2007?
Depending on what version of P6 and what version of MS Project you are using, you could use the project link functionality, this allows a project to be 'checked out' for updating/managing in MS Project and then checked back in once you have finished?
Andy
