Global Change Problem
B
Bert Ella 👤 Member for 15 years 3 months
To all Primavera P6 v7 masters,
I have a problem in Global Changing, specially when i choose WBS in parameters the value is not working and it states that "'' is not a valid integer value", how can i fix this problem?
Please help!
Thanks and regards,
Did you tried defining the UDF as a "Text" field and then applying the Global Change from a text field to another text field?
Sorry, I am not a P6 user but common sense tells me this can be a possible cause.
S
Steve Campbell 👤 Member for 15 years 1 month
I had the same problem.  Primavera issued a hotfix for this, I believe it is Hotfix #2.  Check the Oracle primavera site for an answer.
B
Thanks John,
Your suggestion is good and i am doing that way but it takes so much time to type all the preceding WBS specially when you have 6 levels WBS in your program. Is there no other way to fix that problem?
