P6 R8 Web App URL
I am currently experiencing problems accessing the web app. I have installed and configured the application (both MS1 and Admin Server) using the admin server configuration panel. My final stumbling block I believe is the correct URL to launch the application. I have seen a number of suggestions (the video - 1275445.1 has 2 on the same screen (last slide!).
http://localhost:7003/p6/action/login
and
http://webserver_name_or_ip_address:7003/p6/login
The webserver name is a red herring as the example they show on the video is local host.
I have also been advised to try
http://localhost:7001/p6
That doesn't work either.
Can anyone offer any further suggestion?
Many thanks
Simon
M
Manik Nath 👤 Member for 19 years 7 months
Just found the solution to this....need to start the admin server for weblogic server first as in my case the application is deployed on weblogic server, then use the following url
http://<servername>:7001(orwhatever port your weblogic is configured to)/p6/action/login
Manik
M
I am facing the same problem....I have installed P6R8 web and also deployed it using weblogic, in the weblogic administrator console the status is also saying active and healthy, but i cannot find the URL to access the application....can anyone help me in this, its quite urgent.
Many Thanks,
Manik
