Primavera P6 Versions
Hello
Can anyone confirm 1. if this is possible and 2. any negative effects?
SQL server. All clients are currently running 6.2.
We have to rebuild a laptop and I'm wondering if I can install version 6.7 on it and use it along side the other laptops running 6.2
Wanted to check as I am not sure if the 6.2 machine would be able to open a project created on the 6.7 machine?
Thanks in advance
David,
When you say, “use it (the P6.7) along side of the other laptops running 6.2” I assume that you are referring to all laptops running stand-alone versions of P6 and not a networked group all connected into the same, common server.  If this is what you mean, then you should have no troubles exchanging XER files.  There might possibly be problems reading a P6v7-created XER file in the P6v6 environments, but I do not believe that there will be difficulties with a P6v6.2 reading a P6v6.7-created XER file.
If there are any difficulties, the problem is simply with the first line of the XER file.  There is a well-know trick of opening-up a later-version XER file using a simple word processor such as Notebook (or even with Excel) and changing the part of the first line where it says, “ERMHDR           7.0       2010-09-10 ….” And change the “7.0” to “6.2” and saving it again.  Then the earlier version can read the later version’s XER file.  Good luck!
Roger Booth 👤 Member for 19 years 7 months
Hi David
We did exactly the same and found out that 6.2 does not appear to be compatible with server 7.0. Obviously then had to update all our client machines to 7.0. Since then though no problems. Now running 7.1 with 7.2 downloaded and ready for update (when we get round to it)
I
Izam Zakaria 👤 Member for 20 years
Hi David,
It won't happen, I've confronted this problem before.
Perhaps others can give some advice and proposal.
Aizam Zakaria
