Primavera SDK
M
mimoune djouallah 👤 Member for 19 years 8 months
Jeff,
I have installed the sdk, and made queries to change the level to 7, but I am a little lost in all those table, I want only to query the labor cost spread by financial period, but I am not sure which table to use, in the sysoptions table you can change to d,m,h,y,q but not financial period, do you have any idea ?
regards
Mimoune
dee tee 👤 Member for 15 years 4 months
Hi Jeff,
I'm pretty new to this site and I am having difficulty connecting to the SDK DSN via anything really. I don't have ms access to do a test but I know that the BDE database connection is good.
I'm using p6.2 and ms sql server express 2005. I have been using test code to connect via a vb/jscript. None have worked.
Here are the errors:
Microsoft OLE DB Provider for ODBC Drivers: [ATI][OpenRDA ODBC]RDA error: Resource not available - Connect error: da=PMSDK; Driver=PMSDK;engine=PM;lf=C:\temp\PMSDK.LOG;lo=terse;pg=1;pp=pubuser;pu=pubuser;
Error returned from engine: UDB.Connect; hResult=0x80040003 (PMSDK_E_INTERNALERR: internal driver error); EOleSysError=Invalid return value from CreateAppVDB Error number: 0x80040003
Microsoft OLE DB Provider for ODBC Drivers: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
Microsoft SQL Native Client: Object was open
Please help, I cannot run my scripts. I am using wsf, jscript and vbscripts via windows cscript to execute the scripts. None have connected successfully so far.
Dee.
J
jeoffrey reyes 👤 Member for 18 years
Hi Isabelle,
Send me a PM of your email and I will send you the Guide for SDK. It is very simple and easy to follow.
See also my thread STEP-BY-STEP GUIDE USING SDK there were some discussions that might help you.
JEFF
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
