What is Actuals in Schedule options
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
Hunais M J
Soheil Barekat
henrigpc
Hashil Ali
I am currently migrating from P3 to P6. In one of our reports - Variance Analyis in P3 filter I can define the filter the following:
if Actual dates Is WR DD-30D DD+0D
where Low Value = DD-30D
High Value = DD+0D
In P6 the Actual dates is not there... it was changed to something. I tried to use the Planned Start or the Actual Start but the result was different than I expect. Can you help with this? Thanks.
quartz
High Value = DD+0D
quartz
Progress override means ignore the logic while Actual dates is not but using actual date when calculating forward pass and backward pass. Below is example of the difference.
