Risk Impact calculation
a) The answer is NO. You can only select the start date when the risk is going to occur. The range is the number of impact days or units x % of impact.
b) The reason why current & current+impact date are the same is you apply a risk to an over allocated resources which prevent P6 from levelling the resource. Meaning if resources assigned to activiy under WBS is exceeding from the max unit/time set on resource Unit & Price then P6 will not level the resource.
Ex: resource1 having max unit/time = 8/d and assigned to 5 day having budgeted unit of 50 units then unit/time = 10/d which is exceeding from max unit/time (8/d) therefore P6 will not level the resource and date will not be calculated even risk is applied but impacted cost and units will be calculated.
c) same answer as b)
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
