Resource Codes
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Haresh,
Resource Code is used only on Resource Window (Module). It will not available on Activity Window and Project Window and the equivalent is Activity Code for Activity Window or Project Code for Project Window.
Note:
Code use for Group & Sorting, filter, show on column.
Project Code = Project Window, Activity Window but project level and not activity level.
Resource Code = Resource Window and Resource Level only.
Activity Code (Global, EPS, Project) = Activity Window, Resource window but activity level only.
Dear Rodel,
I assigned these resource codes to all resources. But i am unable to understand , how to get benefit from assigning separate codes to all resoruces..
The concept is not going into my head.....can you help me out, how can i take benefit after assigning resource codes??
Haresh,
Resource Codes are only for resource. You can assign resource code by selecting Enterprise-> Resource-> Code Tab or Show the created code column under this module (Enterprise-> Resource-> then right click and select the resource code created)
