Price / Unit allocation in Roles........
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Haresh,
You can define as many rates in roles but you can only use 1 at the time. If you want to use Price/Unit 2 or 3 etc…, you need to change the settings in Project Window under Resources tab-> Assignment default then change Price/Unit by clicking drop down box selection to any rates you wanted to use before adding new roles assignment.
The reason why your budget remains zero is your rate source still using resource instead of roles. If using roles rate you need to change the rate source to role. You may also need to refresh the cost by select Tool-> Recalculate Assignment Cost. I have explain 3 option of how to use different rate in P6 (click link below)
Cost coding of Activities Post #29
If it is not clear to you let me know so I can help you further.
