Overallocated Early Units
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Dan,
If you have a parallel activities using same resource and your max unit/time is only 8 (for example) and both activities using 8hrs/day per resource then 8hrs will be over allocated. You can level your resource but it might push your activities. Another way is to increase your max unit/day to max resources that your going to use per day.
Another cause is if max unit/day =8 and duration is =5days but resource is 50 unit then it equals to 10hrs/day. Resource profile will show 2hrs/day over allocated.
