Display Single activity per project
V
vince peck 👤 Member for 16 years 4 months
Arnold Puy 👤 Member for 19 years 1 month
You are welcome Vince. Planning Planet Members are here to assist and guide you.
Arnold
V
All
Many thanks for your kind suggestions. Using the information supplied so far probably a mix of these ideas.
I will feedback to our planning group the idea of either dumping to excel or applying a global change making the next activity say X% complete then re-import. After that our organisation will need to get into the habit of best practice eg once an activity has been 100% complete then mark the next activity as started. Then apply the filter suggested by Arnold will then work. Do a proper job eh?
I’ll keep you posted.
Vince
Hi Vince,
Why not try the suggestions of Alexandre & Rodel.
Or if you don’t mind, try to send me the .xer file so that I can look at on it and let us sort out the dilemma.
Arnold
Vince,
Is your project does not have any parallel activities? If it has then best way I can advise is to create a users define field priority or any name that you can use to identify the next activity then use that as a filter.
Alexandre Faulx-Briole 👤 Member for 23 years 4 months
Hi Vince and Arnold,
IMO, it would take some VBA lines to get what Vince says:
1. make sure activities are sorted by Early Dates
2. browse until we find the last 100% completed activity and select it
3. determine what activity is the 1st successor timely speaking, and select it
Feasible in MS Project which includes and understands VBA; does Primavera RA allow to do the same?
Alternatively:
1. Export to Excel,
2. Select activities in Excel the way above,
3. Define in the Excel file some kind of filter P3 will understand
4. Import in P3
Is it worth the time it will take? Or easier-faster to do it in P3 with the filter ArnoLd suggested?
Please let me have you comments,
Alexandre
V
I put your idea to the commmittee and they said:
’Nice try but with some of the year plan stuff it can have a start constraint so first activity may not start for months, so would filter equipment out
Although I guess that would suggest the equipment is not started…. So would be OK
and
With activities having duration of 1 hr, this would lead to multiple line items being shown.’
Many thanks all the same.
V
You got it!
If the activity is started but not completed, or in progress or even have not started then this would be deemed as next task and it’s just that one we need to view.
eg
Project: Replace seal from pump
Activity 1 Erect Scaffold 100% complete
Activity 2 Isolate pump 100% complete
Activity 3 Overhaul and replace seal 0% complete
Activity 4 Recomission 0% complete
Activity 5 Remove scaffold 0% complete
So the schdule we would like to see would look like this:
Vince
Hi Vince,
I pessumed that you update monthly, and considering the in progress as the next task then try this:
(Any of the following)
Where
Activity Status "equals" In Progress
And
Start "is within range of" DD DD+1M
Arnold
Hi Vince,
Correct me if I am wrong. You mean you need to show one activity per project. Since there is a lot of projects to be monitored, all you need is to show only one activity per project with the next task only.
What if the activity is already started but not yet completed, or still in progress? Do you consider this as your next task? Just a query.
When do you update the schedule, every week or month? Or maybe can you cite one example for me.
Arnold
V
Thanks Arnold, almost there.
The activity status not equal to completed does half of the request.
The second part of the equation within the filter would indeed function but having many many projects it would take some considerable time to apply that filter to each project.
We download a thousand or so projects (some large jobs some small) each have 1 or more activities. Therefore the filter suggestion would only work with one activity.
The request is to issue a schedule to our term contractors showing the next task only.
Vince
Hi Vince,
Welcome to Planning Planet.
If I understood you correctly, you can create a filter say:
Where
Activity Status "is not equal" Completed
And
Activity ID "contains" or "Equal" (Act ID Value)
I am not sure if this what you are looking for.
Arnold
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
