Reports - Report Scope Column
David,
The best way to check is this process.
First you need to logoff to Primavera then ask your colleague to logon using your Users Name and password. If the issue still the same then there is a problem with Primavera installed in his machine otherwise something wrong with the profile.
David Blades 👤 Member for 22 years 2 months
Hi Rodel
Yes he has global access. In fact when checking it looks as if he has the same Admin Superuser access as I do.
A strange one!!!
David,
Can you check if he has a global access under User -> Global access Tab-> Global security Profile. He might not have global access privilege.
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
