opening project activities not showing directly
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
ok i will use it from activity window only then
thanks
Pinan,
You mean even if you are in Activity Window and press Ctrl+o and open a project it goes back to Project Window?
still the same if i use ctrl o or file-open
it still not directly opening to activity layout
Sorry Pinan,
It’s weird and I haven’t encountered that problem yet. Can you try to open project from the Activity Window if you will have the same problem? (File-> Open or press Ctrl+o)
hi rodel
its not about startup window, my default is activities,
what i am trying to do is after picking up a project that i want to open, i right click then open project at project layout, but activity layout doesnt show. so i need to click from project menu then activities to open the activity window.
hope you have an idea
thanks
PINAN,
You can set the start up windows under Edit-> Users Preferences then select Application tab. Under Application Startup Window change it to Activities.
