RL05 report - issues
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Thank you Rodel... you are indeed a master!!!!
F is for Fiscal Period. You can change that to normal calendar if you wish.
To change Goto Report. Select the report you wanted to modify. Click the wand or Wizard button and click Next until you reached Date Option. Click Timescale and under Date Format tick calendar instead of Fiscal then click Ok. Click Next until you reached to Finish. Click Save Report then click Finish then run the report again.
Rodel
Many thanks.... this appears to ahve done the trick.
Only thing I have noticed is that the dates are as follows-
F2/1/2010 F2/8/2010 F2/15/2010 F2/22/2010 F3/1/2010 F3/8/2010 F3/15/2010
Do you know what the F prefix is for and can I remove it??
Thank you again
David
David,
Check your currency settings under Edit-> Users Preferences then click currency tab. Make sure that Show currency symbol is tick and Show decimal digits is tick.
When running the report using ASCII Text File make sure that Field Delimiter is comma (,) and Text Qualifier is double quote (“) and tick view file when done. Also make sure that the extension of file is CSV
