How is setting Public Holiday in P6
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
mch 714,
it is no longer possible to create repeating non-working days in P6 as it was in P3; nor to have a holiday postponed to the closest working day if it normally occurred on week-end
Alexandre
First I thanks for your reply. My mean is how set holiday on one calander of P6 menu. As example, 1 May of the labour holiday define to no work date and can be appear to every year. it’s no need one by one define it as P3 repeat to every year.
mch 714,
Create 2 calendars:
CAL 1 = working days and public holidays
CAL 2 = Calendar days (all days are working days)
Make CAL 2 as your global calendar.
R. Catalan
mch,
Select Enterprise-> Calendar from Primavera menu. Then select which one you need (Global, Resource or Project) to create. Click Add or modify existing and define it from there.
To assign to activities, Click column icon then under General double click calendar. Click the calendar column and select the calendar you want to assign. Highlight all activities start from the column that you already assign and press Ctrl+E to fill all selected activities.
