Level of Effort
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
@Ijaz,
Thank you Ijaz, Ill try that.
@Dieter,
Thank you for your valued response.
but the problem is,
unlike P3 ver 3.1 hammock activity, in P6 we can not add same activity as pred. and succ. for "Level of Effort(LOE)" activity in Level-1.
my problem is as below,
i have L-3 activities, which should be rolled up to L-1 as summary. for example Act L3-1, L3-2, L3-3 should roll up to Act L1-1 (L1-1 set up as LOE activity with Pred. SS to L3-1, and Succ. FF to L3-3). if i change any act duration in L3-1~3, L1-1 will change automatically. but if i have only 1 act in L3 which should appear in L1 also, i cant make L1 act as LOE.
However, ill try Ijazs method to try again.
Thank you guys for your guidance.
BR
Sumit
Sumit
In my opinion this is a real exception that one single activity (not milestone) is put into level one. The limit is correct, that an activity cannot have the same activity as predecessor and successor.
Two ways: Include the working activity within level 1 or add a milestone.
By the way: How do you define level 1?
Hi Sumit,
Try changing the duration type of level 1 activity to Fixed Units. I think it will help.
Ijaz
