Copy of Project
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Hai Arnold
Again u helped me ...
Thnxs
With regards
Arun.V
Hi Arun,
With P6, the solution of your problem is very simple.
How to copy a project.
1. Go to Enterprise --> Projects, highlight the project you want to copy. Simply right click then select "Copy". Right click again then select "Paste" . You can paste it anywhere you wish in the EPS node, all the check box must be marked and select OK.
2. Open the project you want copy and go to File --> Export --> Primavera PM/MM - (XER).
How to maintain and assign baseline.
1. When you finish the step #1 on how to copy a project, open your current project and go to Project Menu --> Maintain Baselines... Select "Add" you can select a "Save a copy of the current project as a new baseline" or "Convert another project to a new baseline of the current project" then select OK.
2. When done, go to Project Menu --> Assign Baselines...Now you can select a Project Baseline or User Baselines..
Arnold
Thxs George
I think you need to enroll P6 tutorial class
