Importing P3 Planner Files to P6 Ver 7
J
Jim McCombs 👤 Member for 21 years 7 months
I understand that starting with version 6.2 of P6 that unless P3 is already installed when P6 is installed, then the button for importing and exporting p3 is grayed out.
If P3 was installed when you installed P6, then I would suggest that you get help from Oracle (good luck).  I don't know why Oracle has to make it difficult.
Arnold Puy 👤 Member for 19 years 1 month
Hi Robin,
I think you don’t have the users access privilege to import P3 project.
Arnold
Robin Kilmister 👤 Member for 19 years 2 months
Hi Yasser,
I have read your thread but I do not have the same problem as you.
I have P3 installed on my machine.
I do not get the choice to even import the P3 plans to P6 as the choice toggle is greyed out on the import tab. I think that there is an internal switch on the P6 programme that needs checking or I do not have compliant software for the import?
Robin
Y
Yasser Elyosefi 👤 Member for 21 years 3 months
Hello Robin,
Revert to my thread titled
" P6 Ver. 7 bug when importing from P3 "
It is a software bug in V7 as well as V 6.2
Yasser
Y
Try not to use the backup files.
USE the folder into which the P3 files are copied (from copy function not Backup)
GeoVe
JAGAN REDDY MUSUKU
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
