P6 Organization by Resources
D Artagnan 👤 Member for 17 years 8 months
Arnold Puy 👤 Member for 19 years 1 month
Hi D,
There is a workaround. If you want to group your activities by individual resource and you need to show the gantt chart or bars in the activities window then try the following;
1. Create an Activity Code and rename the same Activity Code Description with the Resources Name. When done...
2. Filter all the activities assigned by each resource and assign the newly created activity code using the "Fill Down" or "Assign Activity Codes" located at the right corner of your monitor.
3. When done, go to "Group and Sort" and group by the activity code assigned to it.
Let us know if you have done this.
Arnold
Thanks. I got this part.
The only thing is it doesn’t show the bars. Is it possible to do it so.
Thanks Arnold again.
Hi D,
You can organize Resources individually using the:
1. "Resource Assignments".
2. "Resource Usage Spreadsheet"
Arnold
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
