Importing data with P6 v 6.0
E
Eric EVRARD 👤 Member for 19 years 6 months
Arnold Puy 👤 Member for 19 years 1 month
Hi Eric,
The Duration % Complete cannot be modified using Excel sheet due to (*) sign while Actual Start can be changed. If you want to alter your Duration % complete in excel then you need to create and assign the UDF (User Defined Fields) say DUR%COMP.
The UDF need to include during exporting data and change it using excel sheet. When done, export it back to P6.
Create and Run a global change with corresponding parameters:
Duration % complete = DUR%COMP
Make sure before running the global change you need to have the actual start for each activities to be updated.
Arnold
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
