primavera sdk
L
liu yi 👤 Member for 18 years 7 months
L
thanks you two!now ,i have settled the problem.
K
Kevin Button 👤 Member for 22 years 11 months
Lui yi
You will probably find the help files at "C:\Program Files\Common Files\Primavera Common\PMSDK\Doc\index.html" but unless you have some knowledge of the Primavera database structure you may end up creating more problems for yourself. You would also need to be familiar with running queries in your chosen database management tool. I use MS Access because it’s all I can get at work but it does everything I want anyway.
L
thanks at first.now , I want modify the activity’s resource assign by SDK.and now ,at resource lib,add the resource.how can I to do?then,I open the Projwbs table by powerbuilder ,but not at all?how can i config or operate?
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
