Cost of Same Resource Working at Multi - Projects
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Dear Amanullah,
It depends on the level of management that you are running.
If you are managing the three projects with three separate programs, then you can assisgn the resource for the same code for each project with different unit rates and different number of hours. You keep tracking of your projects and resources.
Best,
Samer
Amanullah
Three ways:
1. you have different rates for a resource in the master data. In the view "Projects" --> Tab resources you can indicate one of the rate types as default - for ALL resources.
2. When you assign a resource, you can select the rate type for each assignment (Column "rate type")
3. When you assign a resource, you can overwrite the rate for each assignment (Column "rate source" must be set to "overwrite")
Hope that helps
