Primavera P6 installation???
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
I suggest to open the license txt file using Notepad and check the version of the license file
HTH
Alex
Hi.
You do not need to connect to internet while installing.
The point is to get the right Registration key.
It was supplied by your software supplier.
Hi Yasser,
First of all, if your licensed is not valid the installation will not continue installing your P6. According to you that you completed the installation. Besides, if you are trying to open P6 you are not going to type the Login Name, only the Password and make sure taht your Database is "PMDB".
In addition, even though you are connected to the internet you can still install your P6.
If your Licensed is Valid, try to install again using the correct procedure. Thanks...
Arnold
Should I be connected to the internet through the installation process or not?
Hi.
This version of license if protected by Registration key, beside the license file.
Kindly contact your supplier to have the right key. To be sured in entering the key ,youd better "load the file". Do not enter by keyboard.
