Resoureces Charts in P5
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Hi Dieter:
I got it thank you very much for you help
Armando
Aman
My text was different.
But to explain it in a different way: Resource usage profile window has four quarts. Upper left: Activity table, Upper right: Bar chart, lower right: histogram (or spread-sheet), and lower left the resources or roles. on top of this screen (lower left) you see "display" --> mouse click --> select view --> "Role" or "Resource" what ever you want. This should work now.
Read the help text
I got it.
Thankx.
Dieter,
What do y mean "from left select profile discipline or resource" IT DOES NOT WORK; Please explain.
aman
Hi Armando
View --> Show on bottom --> Resource Usage profile --> "F1"-Key (Help) --> click on "Resource usage profile" and youll be guided.
Left from the profile you can select Role (=discipline) or Resource, then just try until youll see what you need.
Print: File --> Print preview --> Walk through the detail tabs. "Apply" will show you the result of your adjustments without leaving the function.
