P5 Allocation Limit
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Hi.
Allocation limit is set when you use "Planning resource" function (only available in Web module).
Bryan,
What allocation Limit?
Resource Availability, Role Quantities??
Also were you aware that in P5 the Web - My Primavera only uses summarised data.
So you should have a job service set up to summarise your projects each night. Also you should set your Level of Summarisation at the project level somewhat lower than the 2 default if your after any sort of detail.
Andy
