relationship types
M
Marcio Sampaio 👤 Member for 20 years 7 months
Alex,
I agree.
But I think that our frined is ahead of an specific case in that he could use both relationships he mentioned, and i think it is possible in specific cases like complementary activities.
Thinking in this possibility, i gave my suggestion.
Sometimes, when we read a msg, we have to interpret the question. Sometimes we do it right, sometimes we do it wrong. But i will always try to help inside of my possibilities.
Regards.
Alex Wong 👤 Member for 23 years 4 months
Marcio
Please read the original message, "Is there any recommendation on using relationships in pm software?"
There is no perfer relationship, it should be the true logic between activity. ie you may able to achieve the same float between activity during planning stage. However, if the relationship is not set correct once there is progress then you may have out of sequence activities in your CPM.
Agree??
So it should be driven my the true nature between activities instead of perferred relationship in PM Softwarae
Alex
Hi Gents
Sorry I have to said that it seem that you all got it wrong.
Its not the software driving the plan, its the true logic that is required to drive the plan.
You have to ask yourself, can I start the second activity before the first one finish, or can both start the same time with a time lag, Why there is a time lag, if the time lag is actually a activity. These are the question you have to ask yourself to do planning, the true logic behind the activity, not the software tell you which one to use.
Good Luck
ALex
Dayanidhi Dhandapany 👤 Member for 23 years 3 months
Always Finish to Start relationship is the prefered relationship in PM, but you need to have fine level / detailed breakdown of activities in order to implement this relationship, during the absence of such information, one can tend to use FS with negative lag or SS / FF with positive lag both have their pros and cons.
HTH
M
My recommendation is:
Simulate the use of the two options and see which will go to reach the desired result.
Regards.
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
