Does P3 support project version history tracking? For example I would like to view an audit trail of project changes and potentially roll back changes if needed.
Thank you,
Thank you,
If you latter move on to P6 this might be of interest, is not within P6 but maybe can do it.
http://www.etimemachine.com/data-integrity/audit-trail
rafael,
thanks for guidance + assistance
mike
Mike,
From,
http://ronwinterconsulting.com/Making_CPM_Transparent.pdf
If looking for an audit trail as defined by Ron Winter I am not sure if this is available for P3, "much too old to have this!" is also my suspicion.
I use Spider Project and it provides for both within the software. I rarely use the audit functionality we call Protocol of Actions, not even as a sophisticated undo. It shines on multiuser enviroment where you want to track by who and when changes are performed, but I am currently working on a single user enviroment. The table can grow fast, you can set a limit on the size of the table or use filters on standard and user defined fields for this table. This is very simple but powerful functionality.
If you are looking only for file comparison functionality I suggest you use Ron Winter Schedule Analyzer it comes with many other goodies, though not with an audit trail per se. I advocate only for supported software, in case of problems the developer will be available to help you. P3 is no longer supported but 50% is better than none. A file comparison can be easy but the additional goodies are more advanced. Ron Winter is a frequent visitor to PP and he is always available for help.
Hi Mike,
there is no such functionnality in P3, much too old to have this!
Eric H.T. Chou had in the past developped "HTC-NETCOMP" to do the job, still available for download at http://www.htcprojectcontrols.com/Software.htm
Alexandre
