Hello, Please what is the right thing to do when you extract a PRX file in a folder that already contains P3 files, The prog ask u if you want ti overwite ir not.
K
K
Alex,
THanks. Are u saying its not good practise to extract different schedule(differnet project) in the same folder. If I got u rightly, only updates or revision of the same schedules should be etracted in the same folder
Bobo
Bobo,
if the P3 schedule contained in the PRX file is a newer version of the one in the P3 folder, the obvious thing to do is to overwrite the older version; if not, you would better extract the PRX file in another folder
Alexandre
