Windows 7 and P3 compatible?
I
Ivan Botha 👤 Member for 20 years 9 months
As stated before P3 runs just fine on 32-bit Windows 7 but not on a 64 bit system. SureTrak does not run well on either versions of Windows 7 nor Windows 7 compatibility mode.
In order to install P3 on a 64-bit Windows 7 system I suggest you download from MS site their free virtual machine. This will create a separate window where windows xp will run. This windows xp is part of the download. There will be some software and hardware requirements but if you got a new machine most probably it will handle it. Not sure it runs in all Windows 7 versions. I am running it on Windows 7 Pro 32-bit installation.
http://www.microsoft.com/windows/virtual-pc/
Note that compatibility mode and windows xp mode are not the same thing, the terms are confusing.
Virtual PC
You will need to install windows xp updates and a separate virus protection license, especially if you wish to run IE within the virtual machine. AVG antivirus is free, Google it, free edition is as good.
C
Cobi Obi 👤 Member for 16 years 2 months
How do I go about installing P3 on a 64-bit Windows 7 system?
Treighton,
If you have a spare license of xp from a discarded pc you can set your 64 bit system to dual/multiple boot with XP32 and XP64, you can even add any version of windows 7 or a combination that best suit your needs. Then use your software with the operating system it was designed to work with. The same goes with a new computer. You will have to work out the activation with Microsoft but can be done.
With disk partition software maybe you can install the second operating system without reformatting your disk. If you move to windows 7 x64 you might have issues with the drivers of your existing hardware such as printers, scanners, plotters, even your computer might have issues. The same goes with a new computer, you can still face issues with your other hardware.
I am not an expert but as anyone try my best, better make sure you ask an IT person.
T
Treighton Mauldin 👤 Member for 16 years 4 months
I am very curious to hear if anyone has had any success in using the emmulation of x32 XP on a x64 Windows 7 machine. I am currently using 2 machines on x32 XP for Scheduling and a x64 XP for CAD/Modeling/BIM/4D work.
I would really like to carry around one machine.
Please specify P3 and Windows 7 version, particularly if a 64 bits version. I believe there is XP emulation under some Windows 7 versions, some comments on this regard is welcomed as even under this emulation, Btrive might be uncompatible depending on the P3/Btrieve version.
In order to avoid as many issues my next notebook will be using a 32 bit version of windows, this also should help me get updated drivers for my hardware as some vendors might be reluctant to provide drivers for a 64 bit operating system.
P3 runs just fine on 32-bit Windows 7. You don’t even need to run it in a compatibility mode, just install and run. (Just don’t try this on a 64-bit Windows – there you will experiance disappointment.) Good luck!
