UPT import in P3
okay, Ive finally done it with the activity codes option, and it worked.
I still dont get why it didnt work with the standard way, but nevermind.
thanks for your help !
hi
i thrust you could run global change even without doing the above said procedure .
you could fix the condition in global change and you can proceed further
you mean importing my stuff in activity codes and forwarding it to the right fields with a global change ?
Ill try this, thanks
I guess you could try using global change
