Dear Team Member,
Please advise in Primavera p6 (R8.3) from cost loaded schedule; how to adjust secondary axis value to 100% in S curve.
Thank you,
Masud
Dear Team Member,
Thank you,
Masud
you cant if you want to adjust it copy cut and paste the data to excel and play with it.
Masud,
The X Axis is timescale where the last activity's completion date is the right hand limit (timescale should be set to PS to illustrate 100% of contract time.)
To show completion cost most clearly on your S Curve, use both Planned and Actuals lines. Planned intersects the Y Axis at 100% contract value, slightly lower than your highest incremented Y value. The completion value is usually slightly lower than the top of the Y Axis for clarity in the graphic and to show its intersection against next the increment in Y values.
The variance between the Planned and Actuals S Curves is the big focus.
I typically show the Legend defining the lines, then double click the Data Date to get a summary pop-up for the project weekly total and cumulative values (actuals intersecting the Data Date as Y Axis.)
I hope this helps. The P6 S Curve is highly configurable and prints to the satisfaction of any contract I submitted against. Print Screen and paste it into your favorite graphics application to clean it up. You can insert insert a text box to add data like the dollars at completion, etc. Read your specific contract to see what is required and build a View.
Save that View and all your S Curves will have a professional and uniform Look and Feel.
Vic
