Primavera P6 Software Development KIt (SDK)
F
FR L 👤 Member for 13 years 8 months
Hello All;
I have installed Pruimavera P6 Version 8.2 Standalone on my laptop & Configured the database.
Then I Run the setup again and chose "change"
After this i selectd The "Software development kit installation"
Then I Configured the database again named "PMSDK"
I selected the user name as  "pubprm$pm" & Entered the same password that i entered during primavera installation (Prima123Vera).
Now "PmSDK" is also configured successfully.
Now I am Getting 2 data base "PMDB & PMSDK" when I run P6.
I followed these all steps through a tutorial 7 Did not do by own.
Now the issue is that what to do next to connect Primavera to excel. (I have the utility files for SDK but in those files I am not able to work)
Can anyone clear me the concept for using SDK.
Andre Greyvenstein 👤 Member for 17 years
I am new to the whole P6 experience, just installed v8.2 myself. I used to use RA with P3 extensively, and therefor starting with P6 my first interest was on how to access the data 'throught the kitchen door'
I dont quite understand the intended concept behind what the call the SDK (Software Development kit). I did some setups on different machines with different settings, some with and some without the SDK. It seems to me that installing the SDK does nothing more but create a database alias to connect to an existing database - so where does Sortware Development come in? I achieved exactly the same by NOT installing the SDK, but create Data Connections through the Control Panel (in Windows 7: Control panel> Administrative Tools> Data Sources (ODBC)). I managed to then access the data from Excel by using ADODB.Connection & ADODB.Recordset objects in VBA.
I am using 3 Databases at the moment - 1 on my local machine, 1 on the server at my work site and 1 on our head office servers. I can read (and write) data to any of the 3 by changing the database name (or alias), with or without intalling the SDK.
To answe you question on the use of the SDK: the way I use it is by writing my own code in VBA. To do this you need some knowledge of Visual Basic Programming as well as a basic knowledge of using SQL.
Not knowing what your intentions are with this and how you want to use it, just keep in mind when writing your own code: Reading (SQL Select) is easy and safe, changing/updating (SQL Update) gets a bit more tricky and dangerous. Adding data (SQL Insert) is VERY dangerous.
Andre
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
