ASTA - P6
Hi all,
I am currentley using Asta V11 but very soon going to be converting to P6.....!! is there a complete difference with these two software packages??
I have never used P6.......!!
James
M
Hi James
I am in the same situation as my current company operates P6 and it is a nightmare getting used to it.
I have convinced the management to trial Asta PowerProject on two new projects and then roll it out on all new starts.
Meanwhile I work in Asta and convert tp P6 in XER which works OK except for the calendars.
Rory Hoban 👤 Member for 15 years 5 months
Hi James
Like yourself I mainly use ASTA V.11
When you use ASTA full time, it will be hard to change over.
you expect things in the same drop down menu but they are not.
I have a copy of P6 but use it very little even after a training course.
Suggest you try a course 1st as a copy of P6 is very expensive
Whats the reason for change company or Self?
Trian Asmoro
Soheil Barekat
Erkan Polater
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
