Precommissioning / Commissioning Activities & Sequence
Angel Cruz 👤 Member for 16 years 1 month
Actually I'm preparing draft schedule for Precommissioning & Commissioning schedule for LNG Terminal Project.
And I come out with these activities as follows:
Precommissioning:
  1. Hydrotest of Pipelines
  2. Leakage Test of Pipelines
  3. Flushing & Cleaning of Pipelines
  4. System dry-out
  5. Inerting
  6. Systematic Conformity Check of Equipment
  7. Static, De-energized Test of Equipment
Commissioning:
  1. Preliminary Check
  2. Functional Check
  3. Operational Test
  4. Pre-Startup activities
May I ask some advise to those who had the same experience on the questions below:
  Q1. Are the activities and sequence are correct?
  Q2. Is there any missing activity?
  Q2. Are these set of activities can be applied to both Utility System & Process System?
Thank you and Regards,
Angel
G
No-one has offered to provide XERs on this thread, and it is 3 years old.
Thread locked.
J
Johannes Vandenberg 👤 Member for 16 years 5 months
Hi Angel
Suggest the following
The items you show as precommissioning and commissioning are in fact part ot the construction, inspection and testing activities.
The basic stream of the process of commisionning is as follows:
  • Complete all the construction, testing, and testing activities
  • Carry out the complete and all the Mecancally Completion activities.
  • Then make a precommisionng plan detailing all requirements of the "Systems"
  • These systems are detailed in the P&I D's. These can be process, utilities, firewater, safyty system, Powergeneration, power distibution. lichting & small power etc.
  • Further plan all recourses, vendor assistances, commisioning engineers, consumables an spare parts, labour for assistance
  • Establish safety and workpermit systems
The next step is commisioning
  • After all the precommissioning activities are completed the commissioning can commence. Take that commissioning starts when the systems "are going live".
  • In many occasions the commissing start with the electrical en instrumentation systems, such as powergenerations and distribution.
  • Then the plantoperation systems shall be done. Etc.
Trust that you answers some of your questions
Regards Johannes
M
Maxime AUTHIER 👤 Member for 19 years 10 months
Hi Angel,
Here some element of answers:
- What you call "Preliminary checks" should be done during or before the Precom (I guess this includes the piping conformity check, instrumentation calibration, machinery alignment, Manhole closure ...)
- For some systems you will not have all these activities (in particular inerting, dry-out for utilities as water ...)
- For gas systems, flushing (with water) and dry out may be directly remplaced by Air blowing
- For process system, you should identify the Safety valves calibration as this often is a critical activity
- Some times could be identified for the closure of blocking points of the punch lists, depending on the way it works on your site
Hope it could help,
Rgds,
Maxime.
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
