Schedule Calculations
There are a range of options for the calculation of dates and float in a CPM network.
I’ve just finished a draft White Paper focusing on the basic calculations and would appreciate comments on the correctness of the calculations and the methodology adopted.  The aim is to produce a definitive document that is generally agreed.
You can download the paper from http://www.mosaicprojects.com.au/PDF/Schedule_Calculations.pdf  All comments gratefully appreciated.
V
Hi Patrick,
the paper is very useful for understanding CPM calculations.
Not everything is applicable to Spider Project - we use additional types of activities, links, and lags. Besides, we don't approve negative floats.
I think that you shall reconsider adding 1 to activity dates.
If an activitiy starts in the middle of th day it is not necessary. I would suggest to write that 24:00 of the previous day and 0:00 of the next day are the same. And set the rule that activity always finishes at 24:00 and starts at 0:00. With this rule the problem does not exist. Actually activity duration may be measured in seconds.
Vladimir
Neil Atkinson
Trian Asmoro
Soheil Barekat
Erkan Polater
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
