waste water treatment plant
Rola Sabbah 👤 Member for 16 years 6 months
S
Saeed Shaikh 👤 Member for 14 years 5 months
[[wysiwyg_imageupload::]][[wysiwyg_imageupload:889:]]
Please allow us to submit you small introduction of our company, products, Distributions and Services and etc. which might be you need to instaling west water plant projects.
ASALI INTERNATIONALEngaged in Manufacturing, Business Development, Sales and Marketing, Supply and Solution etc. for our own products Flow meters, Capacitance Level Transmitters, Level Indicators, Valves, Strainers, and other engineering and mechanical products.
Please find some copies of our new 2012 brochure and introduction in attachment, after your approval and confirmation I would like to have small business meeting with to submit you technical data of our products Flow Meters and etc as per your valuable orders and positive comments.
Awaiting your prompt and positive response.Thanking you and best rgds.
For  M/s. ASALI INTERNATIONAL.
Flow meters & Industrial Products Manufacturing,
Proprietor:-  SHAIKH SAEED.
Contact details:-.
Tel / Fax.+91 (022) 2741 6355
Dir Line. +91 (022) 6565 6355
Cell. +91 8108 55 63 55.
Cell. +91 9768 920 924.
email. [email protected]
www.asaliintl.com
Address:-
OFFICE:- B-137 PLOT NO. J7-J9 KOHINUR INDUSTRIAL COMPLEX,TALOJA MIDC,NEW BOMBAY TALUKA PANVEL DIST. RAIGAD, PIN CODE. 410208,M.S. INDIA.
FACTORY:- 39-40 RAUTARA INDUSTRIAL ESTATE, POST PADHLE, NEAR SHIL PHATA OCTRAI NAKA, MAHAPE MIDC MUMBRA THANE M.S. INDIA.
S
Samer Zawaydeh 👤 Member for 17 years 11 months
Dear Rola,
This is like any other project, you need to start with
Material Submittals (civil, electrical, mechanical and maybe chemical)
Engineering Drawings
Procurement
Construction
Testing and Commissioning
Handing Over
What Gary is describing is the actual process. It is wounderful to be able to understand it in order to be able to monitor the construction and record the progress. Of course, you will be able to identify the Changes from design as well.
Review the BOQs for the material, and the Issued For Construction drawings for the shop drawings to be prepared, and then sit with the Construction team to determine the sequence of construction.
With kind regards,
Samer
G
There are a number of different potential treatment options, so the below is fairly generic. Do you not have any kind of scope or spec to work with?
-Screens & screenings handling plant (metal mesh to filter out major detritous which could harm pumps, etc. Screenings handling might be washing it & conveying to skips)
-Stone / grit removal (eg constant velocity grit channels with dredging pump)
-Inlet pumping station
-Primary Settlement tanks (floating scum removed from the top, settled sludge removed from bottom via bellmouth)
-Biological treatment –either
a) Aeration lanes (settled sewerage passes through aerated channels seeded with bugs which eat biological matter)
b) mineral beds (sewerage trickles through the packed mineral beds, with the bugs seeded on top)
-Final Settlement Tanks (similar process to PSTs above)
-Effluent outflow
In addition, the sludge taken from PSTs and FSTs has it’s own process stream:
Sludge storage tanks
Sludge thickening / dewatering
Then 1 or more of the following :
a) anerobic digestion tanks, with gas being recovered as renewable energy
b) Liming plant to reduce odour & raise ph
c) Incineration
d) Thermal drying (export to agriculture)
e) Pasteurisation
f) Thermal Hydrolysis
Neil Atkinson
Trian Asmoro
Soheil Barekat
Erkan Polater
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
