How to create an project plan?
S
Shah. HB 👤 Member for 17 years 7 months
S
Mr.Mike, i have experianced some concepts from a year of investment in electromechanical field and i will follow the way you stated
Many thanks for your support
M
Hi Shahul
So - with one year experience as Electro Mechanical engineer you should have some idea of how your work fits into the building process.
For instance you can’t fix anything until someone else has built the place to fix it to.
So you will need a detailed construction programme before you can realistically plan any of your work.
Unfortunately you are most likely faced with a very broad "top down" programme where all the detail is lumped together in multi trade - multi location bars.
Therefore in your programme where you need to fix something and you have no construction detail then fix a milestone and work on from there - for instance.
Instsll AHU’s on Roof Plant Deck.
Set a milestone called - Roof Plant Deck Ready - and use a flag constraint to hold it.
Then put in the AHU’s and the systems that they serve.
At the other end you will need to know when the ceiling zones are clear for the high level ductwork all along the duct route.
This will need another fixed milestone if the construction plan is not sufficiently detailed.
You must then send your milestones to the contractor and give notice if any of them are late.
In the meantime keep looking and learning what is happeneing on site. If you don’t know then ask someone who does.
S
Hi Mr. mike I didn’t state 1.6 years,It is my mistake did while creating a profile now i am updating it. I am in electromechanical company of a year experience
M
Hi Shahul
I have just had anither look at your first thread and I would advocate that you start from Level 4 and work up to Level 1.
As Samer said - start with a single task and build upwards to the completion of the project.
You are putting the work down in sequence as it is built in your mind.
As I have often said - If you cant build it you cant plan it.
You state 1.6 years planning - what is your Building background?
S
Samer Zawaydeh 👤 Member for 17 years 11 months
Dear Shahul,
In addition to the remarks made by the experts, kindly consider the following:
The theory of the Planning Process is very well documented in the PMBOK, 4e. If you read it a few times, you can start building us your Program of Works from the basic activities until you complete all the scope that is required from you.
The actual work is done using softwares, which you need to buy and and learn step by step either by taking courses or by teaching yourself.
With kind regards,
Samer
M
Hi Shahul
You can also visit the Planning Engineers Website and look at the paper by Gary France on Questions to Ask beflre Planning.
V
Vladimir Liberzon 👤 Member for 25 years 5 months
Shahul, project plan is the large document that includes project schedule, project budget, communication plan, quality management plan, contract requirements, risk management plan, etc. It is not the question that can be alswered in the forum message. There are books on project management and PM standards like PMBOK Guide that shall be studied first.
If you mean creating project schedule then you can look at step by step instructions that are included in Spider Project Help (Project Scheduling Technique). You can download Spider Project Demo where these instructions are included from http://www.spiderproject.ru/demo_e.php
Vladimir
GeoVe
Johannes Vandenberg
Soheil Barekat
Peter Holroyd
Neil Atkinson
Trian Asmoro
Erkan Polater
Luis Jr Ngade
Ben Welsher
