EVM in the UK construction Industry
T
Tariq Usman 👤 Member for 20 years 6 months
S
Shahzad Sikandar 👤 Member for 20 years 5 months
we have been using EVM for our water/sewarage project within a frame work for a local water company.
United Utilities is also using this for their AMP4 Programme which worth more than hundereds millions.
British nuclear / Defence indrutry is also using it extensilvely in the UK.
A D 👤 Member for 19 years 1 month
References for your use. Must be of some help for u.
Bent, James A (1982). Applied Cost and Schedule Control. New York, NY: Marcel Dekker, Inc.
Brandon, Daniel M. (1998, June ) "Implementing Earned Value Easily and Effectively." Project Management Journal. Vol 29. Number 2.
Christensen, David S. Comprehensive Bibliography of Earned Value Literature. http://www.uwf.edu/~dchriste/ev-bib.htm
Horan, Ron and Don McNichols (1990, September). "Project Management for Large Scale Systems." Business Communications Review 20:19­24.
Hudec, Jim, Gayla Suddarth, et. al, “Experiences in Implementing Quantitative Process Management,” Proceedings of the SEI Software Engineering Process Group Conference, May 1996.
Mahler, Fred and Mark Mazina (1982, February). "Earned Value Reporting Earns Its Keep." Cost Engineering 24:13-17.
Nichols, John M (1990). "Project Control." Chapter 15 of Managing Business and Engineering Projects. Englewood Cliffs, NJ: Prentice Hall.
Niemann, William J (1982, May-June). "If the Pharaoh had Only Used an Earned Value System in Building the Pyramids." Program Manager 11:1­5.
Ruskin, Arnold M (1995, September). "Measuring Project Performance: Acceptably Small Inch-pebbles." Engineering Management Journal 7:5-10.
Raviraj
T
Thanks oliver for the response, i had already sent accross the questionnaire for my research findings to plenty of companies but i was much disappointed by the response as most of them said they dont use it, thats why i decided to put this discussion on planning planet as i was thinking that i might get some good response here, and i really appreciate your response and i hope that more people will respond to my query.
regards,
Tariq
O
Oliver Melling 👤 Member for 19 years 2 months
I have worked at 3 major companies over the last few years, all of which were in the UK, all of which used Earned Value Management.
Tariq, I am also doing an MSc dissertation in Project Management.
If you want to find out peoples opinion on EV and use it in your dissertation then you must form a questionnaire or hold interviews so that you can refer any findings you make against referneced primary material.
Another option is to use secondary data from previous papers on EVM.
I think you will find that many companies use EV, but not all of them use it properly or to its full potential.
Oliver
T
Thanks Stephen,
i got your point and thanks for correcting me, i will try to get some more research papers on this matter.
To UK fellow Planners:
Just want to have a quick survey, to gather some data, how many of you are using EVMS on their projects?
regards,
Tariq
S
Steve Craine 👤 Member for 23 years 9 months
Hi Guys
I can tell you its used extensively here in the UK in the Rail industry
Steve
S
Stephen Devaux 👤 Member for 21 years 3 months
"Bearing in mind, this tool was mainly developed for IT industry but research shows that it is as good in construction as in IT, do you agree to this?"
Say what? Tariq, sorry to disappoint, but EV was developed for use on US DoD programs, not IT. There is a thread I started a few months ago asking if anyone knew of non-DoD and construction companies using EV tracking. The answer is: precious few!
And certainly it’s not being used on the VAST majority of IT projects in the US!
"-comparing US and UK, we are far behind in implimenting this tool in our projects in the UK,.."
Are you sure about that? I honestly don’t know enough about the situation in the UK, but I do have a pretty good idea of the situation in the US. And I’m going to have to ask for evidence of anyone who maintains that EV is in common usage anywhere in the US outside of federal government projects.
All this entirely leaves aside the issues of comprehension of earned value data, the competence with which EV processes/systems are applied, and the ways in which EV is misinterpreted and used/misused.
EV is potentially a good and underutilized tool, especially when used in collaboration with most of the other valuable techniques in the project management toolbox. It is unfortunate if, as you say, it’s not being applied effectively in the UK. I just don’t think the UK is at all unique in this regard.
T
Charleston,
i am not saying we are not using it here in UK, of course its been use here a lot, but what i am saying is that if we compare between US & UK, we as in UK construction industry are well behind in adopting this methodology, that is not what i am saying, but i have seen it somewhere in the literature review for my dissertation. i have sent questionnaire to planners but most of them said they dont use EVM, i am not saying all of then said, they dont use EVM but most of them replied they dont use it, so thats what i want to explore in my dissertation.
If i am wrong please correct me.
regards,
Tariq
C
Charleston-Joseph Orbe 👤 Member for 21 years
Tariq,
My hunch EVM not use in UK.
Not possible. It will be an insult to British pride to stoop too low to there American cousin.
Somehow, UK will always come up with some clone of the EVM.
Charlie
Catalin Suditu
Laraib Fatima
Adrian Fletcher
GeoVe
Abkar Bannayan
christiandt
J Vaartjes
Aidar Kurmantayev
Noe Radovan
