Project Control Management Lingo
M
Marcio Sampaio 👤 Member for 20 years 8 months
Burn rate is a synonymous term for negative cash flow. It is a measure for how fast a company will use up its shareholder capital. If the shareholder capital is exhausted, the company will either have to find additional funding or close down.
The term came into common use during the dot-com era when many start-up companies went through several stages of funding before emerging into profitability and positive cash flows and hence becoming self-sustainable (or, as for the majority, failing to find additional funding and sustainable business models and hence going bankrupt). In between funding events, burn rate becomes an important management measure, since it together with the available funds provides a time measure to when the next funding event needs to take place.
Some claim, that part of the reasons behind the dot-com bust, was the unsound management and financial investor practices to keep the burn rate up, taking it as a proxy for how fast the start-up company was acquiring a customer base.
Aside from financing, the term burn rate is also used for projects to determine the rate at which hours (allocated to a project) are being used, to identify when work is going out of scope, or when efficiencies are being lost.
Regards.
Rizwan Ahmed Siddiqui 👤 Member for 22 years 8 months
Burn Rate: The rate at which cost or man-hours are being expended on a project. or we can say how much money/time/resources are we using in this effort/project?
Rizwan
Moahmed
S Z
Iftikhar Awan P.Eng.
ahmad rashidi
paulciszewski
Catalin Suditu
Laraib Fatima
Adrian Fletcher
GeoVe
