Float Path in Group and sort
I was watching a video in which it used the following picture for group and sort and also filtered the activities on " in progress" and " Not started"
What is the benefit of using this?
Is it for seeing the critical activities? If yes, why not just filtering by " critical"?
( Would also appreciate it if you let me know what is the meaning of float path and what is the use of it)
J
John Reeves 👤 Member for 13 years
Note if you want to use the Float Path, at least on ver 16.1 or older you have to go to Tools, Schedule, Options, Advanced, - the check the box that says Calculate Float Paths, then you have to put a number - I do not understand why it asked, so I just put some random number like 300.  When asked to analyze a schedule - Float Paths is the first thing I do.  Schedules are generally by WBS - you can't follow them, the Float path shows you the sequences straight through- most important down (common sense will over-ride some).
J
Right Click on the toolbar and select the Activity Critical Path Toolbar: see below
Activity-Critical-Path
If your schedule had a multiple path, the best way of checking the driving activity is to use the float path. The P6 r21 had a new tool bar that calculate float path or driving predecessor and successor activity called Activity Critical Path tool bar.
