Copy of activity - activity ID is not following the default settings
IN P6, When an actitivy with Activity ID 1000 is copied and pasted, using the 'increment value 1' the actitvity ID of the copied activity should be 1001.
For most of the projects it is working as it should, but in some projects it is not
Is this a bug? or a setting I am not aware of?
(When pasting the copied activity, i use the setting of "increment Activity ID based on selected activities")
Alexandre Faulx-Briole 👤 Member for 23 years 4 months
Pierre,
Could you give us an example of the unexpected result you've got when you copy / paste the A1000 activity?
Alexandre
Pierre
Don't you have an activity ID "1001" yet? In that case, P6 will number the pasted activity "1001-1" or from the last ID in your project
Alexandre
