Event PPUSP-2728-E
I am getting an event interception PPUSP-2728-E. The details of the error is as follows.
PasteProjectUsingSP returned error -1Error inserting into PROJCOSTORA-12952: The request exceeds the maximum allowed database size of 4 GBUnable to copy tasks in NEW_WBSError creating new wbs
How to resolve it?
Z
Zoltan Palffy 👤 Member for 16 years 10 months
 Click on start All Programs, Microsoft SQl Server 2005, SLQ Server Management Studio
Authentication: Should be SQL Server Authentication
Login: sa
Password: Prima123Vera
Then click connect
Expand the database folder and click on pmdb$primavera
Then up top select new query
next type the following
exec system_monitor
exec data_monitor
then right click execute
Re-run the exec data_monitor until it returns 0 for "Total Rows Deleted/Changed:".
next select new query
type truncate table refrdel
reboot the system
next shrink the database
Login: sa
Then click connect
right click and select Task
then select shrink database
then ok
close sql
P
Paul Zacharia 👤 Member for 11 years 10 months
Access violation at address 0000000000EA5179 in module 'PM.exe'. Read of address 0000000000000018
P
Z
can you click on the error and select More and post that information as well please
P
Thank you Zoltan. My database was Oracle. So I reinstalled Primavera 17 and SQL database. Now I am getting a new error AVAA0-0896-E. Access violation at address 0000000EA5179 in module ‘PM.exe’. Read of address 0000000018.
Could you please advice how to solve this.
Paul
Z
you are over the 4 gig size limit
option #1 is using microsoft sql as you under laying data base (clean POSB tables)
Login: sa
Then click connect
Then type this
updatestatistics project with fullscan ,all
updatestatistics task with fullscan, all
execsp_updatestats
then right click and select execute
you can then celan the POBS tables
then type this
delete POBS;
the right click and select execute
now you can close and exit out of sql
option #2 add another database
option #3 install the full version of microsoft sql (no 4 gig size limit)
Option #4 export some of your old projects to an xer file and then delete the projects
option #5 compress the data base and compress the file
Login: sa
Then click connect
Expand the database folder and right click on pmdb$primavera
Then select Task
Then select Shrink
Then Select Database
Then select Ok
Next
Then select Task
Then select Shrink
Then Select File
Then select Ok
