Project Codes
Ron Beechey 👤 Member for 23 years 11 months
I have 3 projects and all have different Activity Codes for Systems.   I would like to use one common code to be able to group and sort on a layout with all 3 plans.   Can I create a set of codes in one of the projects and then move this to a global level to use with the other 2 project schedules.
This should have been set up at the beginning but I got into this late.
Raymund de Laza 👤 Member for 16 years 6 months
Copy and Paste will do.
Copy all Activity Project Codes to Activty Global Codes. After copying add a prefix to the Global Codes to make them differ.
David Kelly 👤 Member for 21 years 7 months
Ron,
The name that you give a project-specific activity code is just the external label. Internally every code has a unique obejct ID. It is unhelpful that Oracle allows you to use duplicate labels. You cannot do what you want with project specific codes. A Global or EPS level code is required.
S
Santosh Bhat 👤 Member for 21 years 1 month
Ron, Use EPS Level Activity Codes, and add the EPS Activity code to Common EPS node under which each project is placed. This way the Activity Codes can be used across all projects and you may use this common code for all grouping and Sorting.
Of course the same can be achieved by making the activity Code a Global code also.
