Problem installing Oracle Primavera P6 R 8.2
Raul Santos 👤 Member for 16 years 7 months
Hello everyone, I'm trying to install a standalone version of Oracle Primavera P6 R 8.2 on a computer that has Windows 8.1. I have already installed Java (Java 6 update 27), OracleXE and P6. Now, I'm trying to run the "dbsetup.bat" batch file to connect the software to the database, but the Command Prompt window pops up and I get the following error message:   JAVA_HOME IS NOT SETPress any key to continue ... Does anyone know what is the problem or what I might be doing wrong? Thanks in advance for your support.
G
Gün Göksu 👤 Member for 21 years 2 months
Hi Raul,
Your Java Home is not set. not found in path.
To set JAVA_HOME:
  1. Right click My Computer and select Properties (system properties).
  2. On the Advanced tab, select Environment Variables, and then edit JAVA_HOME to point to where the JDK software is located, for example, C:\Program Files\Java\jdk1.6.0_02.
a logoff/logon, or reboot should then do it.
I hope this helps.
Searched for "JAVA_HOME IS NOT SET" in google. clicked first search result.
